Processador-R5Fxxx
🔧 Boot UPA – Processador R5F2154
 Citar
Utilize o boot visual abaixo para conexão correta no processador R5F2154 usando gravador UPA.
Certifique-se de seguir a correspondência correta dos fios com base nas cores do cabo MCU:
🔄 Conversor de Cabos UPA para VVDI
 Citar
Abaixo está a tabela de conversão entre os cabos do gravador UPA e VVDI.
Use essa referência ao adaptar pinagens entre os dois dispositivos.
COR (UPA)
PINO (UPA)
SIGLA (UPA)
COR (VVDI)
SIGLA (VVDI)
MARROM
AMARELO
TDO
MARROM
TXD / TCK
LARANJA
RDI
LARANJA
RXD
ROXO
PRETO
5
VSS / GND
PRETO
VSS / GND
AZUL
6
BKGD / PD3
VERDE
TDO / FLMD1
VERDE
7
AMARELO
BRANCO
PD4 / AN4
AZUL
FLMD0 / TMS
VERMELHO
VDD+
VERMELHO
VCC
FABRICANTE
NÚMERO DA PEÇA / PRODUTO
NÚMERO DA MEMÓRIA EPROM / MCU
PRINCIPAL APLICAÇÃO
DENSO
89170-0D220
R5F61725
Toyota Corolla
DENSO
89170-0D221
R5F61725
Toyota Corolla
DENSO
89170-0D330
R5F61725
Toyota Corolla
DENSO
89170-0D331
R5F61725
Toyota Corolla
DENSO
89170-0E010
R5F61725
Toyota Hilux
DENSO
89170-0E011
R5F61725
Toyota Hilux
DENSO
89170-0E020
R5F61725
Toyota Hilux
DENSO
89170-0E021
R5F61725
Toyota Hilux
DENSO
89170-0E030
R5F61725
Toyota Hilux
DENSO
89170-0E031
R5F61725
Toyota Hilux
DENSO
89170-0E040
R5F61725
Toyota Hilux
DENSO
89170-0E041
R5F61725
Toyota Hilux
DENSO
89170-0E050
R5F61725
Toyota Hilux
DENSO
89170-0E051
R5F61725
Toyota Hilux
DENSO
89170-0E060
R5F61725
Toyota Hilux
DENSO
89170-0E061
R5F61725
Toyota Hilux
DENSO
89170-0E070
R5F61725
Toyota Hilux
DENSO
89170-0E071
R5F61725
Toyota Hilux
R5F61797 com Adap ISP
🔄 Conversor de Cabos UPA + VVDI + CPT Program
SINAL / USO
UPA (pino - cor)
VVDI (cor - sigla)
CPT Program (pino - cor)
1 - MARROM
TDO / TCK
2 - AMARELO
MARROM - TXD / TCK
4 - AZUL
1 - BRANCO (R7F)
RDI / RXD
3 - LARANJA
LARANJA - RXD
8 - VERMELHO
4 - ROXO
5 - VERDE
VSS / GND
5 - PRETO
PRETO - VSS / GND
9 - MARROM
BKGD / PD3 / TDO
6 - AZUL
VERDE - TDO / FLMD1
3 - ROXO
7 - VERDE
AMARELO - RESET
6 - AMARELO
PD4 / TMS (PD4/AN4)
8 - BRANCO ou CINZA
AZUL - FLMD0 / TMS
7 - LARANJA
VDD+ / VCC (+5V)
9 - VERMELHO
VERMELHO - VCC
2 - CINZA
  • Feita pelo Master Fernando.
  • Em boots 12V+ com alimentação externa, não ligar o 5V+ do UPA (vermelho). Alimente apenas com o negativo (preto).
Como gravar o arquivo “clear” usando o CPT Programmer
  1. Conecte o cabo conforme mostrado no diagrama de conexão
  2. Conecte o adaptador de energia e o cabo USB ao programador CPT
  3. Execute o programa cpt.exe (versão mais recente)
  4. Selecione UART e o nome da CPU
  5. Encontre o “clear file” (arquivo de limpeza) no banco de dados no site de suporte em www.carprotool.com/software ou no fórum pinouts scribd.com+9carprotool.com+9scribd.com+9
  6. Dê duplo clique no botão “Write” para adicionar o arquivo de limpeza ao buffer no cpt.exe
  7. Selecione FCK 8 MHz ou 10 MHz
  8. Clique no botão “Write”
  9. Aguarde a conclusão do processo... e é isso! :-)
    10 - PARA O UPA-S TEREMOS QUE APRENDER JUNTOS.
R5F61797
SINAL / USO
UPA (pino - cor)
VVDI (cor - sigla)
1 - MARROM
TDO / TCK
2 - AMARELO
MARROM - TXD / TCK
4 - AZUL
1 - BRANCO (R7F)
RDI / RXD
3 - LARANJA
LARANJA - RXD
8 - VERMELHO
4 - ROXO
5 - VERDE
VSS / GND
5 - PRETO
PRETO - VSS / GND
9 - MARROM
BKGD / PD3 / TDO
6 - AZUL
VERDE - TDO / FLMD1
3 - ROXO
7 - VERDE
AMARELO - RESET
6 - AMARELO
PD4 / TMS (PD4/AN4)
8 - BRANCO ou CINZA
AZUL - FLMD0 / TMS
7 - LARANJA
VDD+ / VCC (+5V)
9 - VERMELHO
VERMELHO - VCC
2 - CINZA
R5F6172 com conversão direta
SINAL / USO
UPA (pino - cor)
VVDI (cor - sigla)
1 - MARROM
TDO / TCK
2 - AMARELO
MARROM - TXD / TCK
4 - AZUL
1 - BRANCO (R7F)
RDI / RXD
3 - LARANJA
LARANJA - RXD
8 - VERMELHO
4 - ROXO
5 - VERDE
VSS / GND
5 - PRETO
PRETO - VSS / GND
9 - MARROM
BKGD / PD3 / TDO
6 - AZUL
VERDE - TDO / FLMD1
3 - ROXO
7 - VERDE
AMARELO - RESET
6 - AMARELO
PD4 / TMS (PD4/AN4)
8 - BRANCO ou CINZA
AZUL - FLMD0 / TMS
7 - LARANJA
VDD+ / VCC (+5V)
9 - VERMELHO
VERMELHO - VCC
2 - CINZA
